2001 Other Chrysler Models OIL GAGAGE LIGHT
2001 CHRYSLER
121,000 MILES • 6 CYL • 4WD • AUTOMATIC
F.ROGERS
MY OIL GAGAGE LIGHT KEEPS COMMING ON I HAVE TAKEN IT TO THE GAGAGE AND THE MACHANIC SAID THAT THE PEASURE IN THE MOTER WAS GOOD THAT I HAVE NOTHING TO WORRY ABOUT THE JEEP RUNS GOOD NO PROBLEMS EXCEPT I HAVE TO PUT IN ANTIFREEZE ONCE A WEEK I HAD THE WATER PUMP CHANGE AND THE JEEP DOES NOT OVER HEAT IS IT ONE PROBLEM THAT I HAVE ARE THESE PROBLEMS CONNECTED?
Apr 4, 2009 at 9:34 AM
EXCEPT I HAVE TO PUT IN ANTIFREEZE ONCE A WEEK-You sure there's no leak anywhere if not coolant could be burning in the cylinders-any white smoke from the tail pipe?
Oil light coming on-check the oil pressure with a mechanical gauge if normal replace the oil pressure switch abnormal could mean oil pump and engine bearings.
Apr 4, 2009 at 11:09 AM
