2000 Other Chrysler Models oil pan leak
2000 CHRYSLER
BIGSLIK69
Engine Mechanical problem
2000 Other Chrysler Models 6 cyl Automatic
i have a water leak coming from my oil pan, and i didnt have coolant so i used water instead...is that dangerous?
Jul 5, 2008 at 11:01 PM
  • CAR REPAIR CONTRIBUTOR
  • 110,190 POSTS
Hi:
Using water as a temporary coolant is not dangerous. However, it will freeze and boil before regular coolant. Therefore, you should replace it with the correct coolant.
A bigger concern is how can coolant be leaking from the oil pan?
Oct 13, 2008 at 9:20 PM
