2000 Other Chrysler Models Oil Pan
2000 CHRYSLER
230,000 MILES • 4 CYL • FWD • AUTOMATIC
SMYTHCORP
My drain plug on the oil pan has stripped.
I just went to the junk yard for a replacement and I am wondeing if I can reuse the gasket if I buy some silicone sealant.
Is this possible or should I buy new?
It is a 2000 Chrysler Neon.
Aug 15, 2008 at 1:46 PM
  • CERTIFIED EXPERT
  • 110,175 POSTS
Hi:
If you mean the oil pan gasket, replace it. Make sure both the engine block and oil pan are clean and dry before replacing them. If you get a quality gasket, you will not need sealant.
If you question refers to the drain plug gasket, it can be reused if it hasn't been damaged. (For the price, I would replace it too.)
Oct 10, 2008 at 3:56 PM
