2000 Other Chrysler Models igntion
2000 CHRYSLER
125,000 MILES • V8 • 4WD • AUTOMATIC
GOOSE3324
when key is inserted the ignition wont turn it seems locked how can this be fixed
Dec 7, 2007 at 10:39 AM
BLACKOP555
  • 10,386 POSTS
are you using the original coded key or a copy? if so you may need a coded key. if you have a spare set that is factory made try that one. if still nothing try some graphite lock lube, the tumblers may be stuck and jamming up causing the key not to turn. If none of this works remove it and replace with a new one.
Dec 7, 2007 at 12:07 PM
