2000 Other Chrysler Models HEATER NOT WORKING
2000 CHRYSLER
TABS
Heater problem
2000 Other Chrysler Models Engine Size unknown Two Wheel Drive Manual 72000 miles
MY CHRYSLER NEON 2CY PURCHASED IN 2000 THE HEATER IS NOT WORKING , WHAT DO I NEED TO DO? IT DID HAPPENED BEFORE AND THE MECHANIC COULD NOT FIX IT BUT THEN IT STARTED TO WORK AGAIN , BU TTHIS TIME IS NOT . PLEASE CAN YOU HELP ?
Dec 17, 2007 at 3:07 AM
BMRFIXIT
  • 19,053 POSTS
[quote:a65cf5b197="TABS"]Heater problem
MY CHRYSLER NEON 2CY PURCHASED IN 2000 THE HEATER IS NOT WORKING , WHAT DO I NEED TO DO? IT DID HAPPENED BEFORE AND THE MECHANIC COULD NOT FIX IT BUT THEN IT STARTED TO WORK AGAIN , BU TTHIS TIME IS NOT . PLEASE CAN YOU HELP ?[/quote:a65cf5b197]
check and adjust coolant level if needed
check or replace thermostat
flush coolant system and the heater core
check the blend door
Dec 28, 2007 at 8:25 AM
