2000 Other Chrysler Models Chrystler Voyager
2000 CHRYSLER
107,400 MILES • 6 CYL • 2WD • AUTOMATIC
MDANDREANO5
All of my guages stopped working. When that happened my ABS light came on and then a few minutes later the check engine light came on. Van still runs fine. Took it to have diagnostic test..nothing shows up except a manufactures code. I need my speed and fuel guages!!!
Please help! What could be causing this.
I checked the obvious fuses under the dash..the one for the guages..what now?
Aug 8, 2009 at 5:29 PM
CH112063
  • 1,320 POSTS
The way to repair is with the manufacturer's service department. They have a manufacturer's diagnostic tool and it does a lot more than just read the codes. It reads inputs, outputs, and resets the computers that are involved. There are three modules from your description that could tell the story easier and with less expense and frustration that guessing will cost you. Sorry that it isn't easier but sometimes you have to do what is required to fix a faulty guage(s) that you require. Good luck. The OBD connector is required by Federal law to hook up and give up any agreed emmission control information only.
Sep 7, 2009 at 2:56 PM
