2000 Oldsmobile Bravada AWD Not Working
2000 CHRYSLER
DAGRAGES
Ok, the one of the right ball joints went on my 2000 Olds Bravda last summer while I was driving at 45 Mph. Thankfully, no crash and I was able to pull it over. I have a Chrysler service contract that covered the repairs (bought car used from chrysler dealership). They replaced all the ball joints and told me that there was damage from the ball joint failure-hub cracked and front axle cracked. They replaced all of this stuff. I have never had any problems with my all wheel drive, but now we got our first snow and it doesnt work. No 4x4 dummy flashing or lit on dash either. What's the chance this is related to the ball joint failure or repair? What does it sound like to you?
Dec 3, 2006 at 11:18 AM
2CARPRO JACK
  • 11,533 POSTS
The smart-track system could be having an issue.GM had issues with front diff actuators. You might want to take it to a shop and have the PCM scanned to see if its a wheel sensor or something related to the previous repairs
Dec 4, 2006 at 4:51 AM
Suggested Repair
Have a shop scan the PCM for codes. Check wheel speed sensors and the front differential actuator, a known SmartTrak issue, and confirm the prior hub and axle repair did not affect the all-wheel-drive system.
Conversation Summary
A 2000 Oldsmobile Bravada lost a right ball joint at speed. Under a service contract, the shop replaced the ball joints plus a cracked hub and cracked front axle. All-wheel drive had worked before, but after the first snow it no longer engages and the 4x4 indicator is not lit or flashing. The expert said the SmartTrak system may be at fault, noted GM problems with front differential actuators, and recommended a PCM scan to check for a wheel sensor or a fault related to the earlier repairs.
