1999 Other Chrysler Models Starting and ignition problem as
PHOEBE3844
  • 1999 CHRYSLER
  • 6 CYL
  • 93,000 MILES
While installing fog lights, hooked to 15 amp fuse marked ignition, next to it is a place for a male wire connector, that is where I got my power from. While installing wires arched. Now the car will not start when key is on on position. Nothing works, radio, wipers, etc. All fuses and relays check good. Battery is brand new. Something happened when the wires arched. Unplugged wire harness from key ignition and did not get any power readings with test light with key on or off. Please advise.
Sunday, August 3rd, 2008 AT 3:04 PM
  • 109,755 POSTS
Hi:
Does the car turn over? If not, let me know what model the vehicle is so I can look at the correct wireing schematic. It may be something as simple as a fuseable link.
Monday, October 13th, 2008 AT 9:07 PM
