1998 Other Chrysler Models voyager 3.3 litre
1998 CHRYSLER
113,000 MILES • 6 CYL • 2WD • AUTOMATIC
ROUMAN
changed battery now dash board lights keep flashing, they go off after 35/ to 40 mins while driving, but the rear wiper stays on?
Dec 5, 2009 at 9:33 PM
HMAC300
  • 48,601 POSTS
frm changing the battery it sounds as if your ground is either loose or not a good connection. YOu should check wher eit connects to the engine an dif the battery has a cable going to the body it should be cleaned and checked as well.
Feb 23, 2010 at 7:16 AM
