1998 Other Chrysler Models Brakes ABS
1998 CHRYSLER
90,925 MILES • 6 CYL • 2WD • AUTOMATIC
TRECEL
My car is leaking brake fluid uncontrolable I have to put brake fluid in about 3-4 times a day. I have tried filling only half-way. There is hardly any pressure at all. I had some untrustworthy shop look at it and it was leaking from/or off the Anti-lock brake system. What would you think is wrong with it without looking at it? I'm hoping it is just a loose hose. Can't wait for your opinion.
Mar 4, 2008 at 8:06 AM
  • 110,248 POSTS
Hi:
It sounds like you have a broken / rusted ruptured steel brake line or a ruptured brake hose. Check under the car for the leak. If you find nothing, check the backs of the tires and wheels for fluid. If nothing, cueck under the dash (driver's side) uo near the steering column. Check if the carpet is wet. If so, check master cylender.
Let me know what you find.
Oct 12, 2008 at 2:19 PM
