1997 Other Chrysler Models no fuel pressure
1997 CHRYSLER
200,000 MILES • 6 CYL • 2WD • AUTOMATIC
DODGEROMEO
I have no fuel pressure and sending unit makes no noise when ignition is turned. Im sure its the pump,filter or relay...it started missing bad on the way to work one day but i made it...after shift it wouldnt start...i have no power at the fuse when i turn ignition but the fuse is fine...i havent checked the relay yet and dont know how to...so thats one question...a mechanic said it may be wiring ..i found wires under back seat to test for power but dont know what colours they are...there is suppose to be some inline fuse or something as well as the block fuse and the relay...dont know where this other fuse is...im sure its the pump...what do you guys think? do you know where the mystery fuse is or how to test the relay as well?..thx:)
Aug 7, 2008 at 8:36 AM
To answer this question properly you need to describe this vehicle. All I know its a Chyrsler-Your shot
Aug 7, 2008 at 9:14 AM
DODGEROMEO
I filled out a form with all details?...it is a 1997 intrepid 3.3L...it has air, pwr windows and about 200000 km,s
Aug 8, 2008 at 11:14 AM
Have helper put key to run-while you check for power at dark green and black at fuel pump module connector-No power test the fuel pump relay fuse A 20amp and fuse no.18 10amp. Got power at FPM check ground-if good replace the fuel pump.
Aug 9, 2008 at 8:45 AM
