I have no fuel pressure and sending unit makes no noise when ignition is turned. Im sure its the pump, filter or relay. It started missing bad on the way to work one day but I made it. After shift it wouldnt start.I have no power at the fuse when I turn ignition but the fuse is fine.I havent checked the relay yet and dont know how to. So thats one question.A mechanic said it may be wiring.I found wires under back seat to test for power but dont know what colours they are. There is suppose to be some inline fuse or something as well as the block fuse and the relay. Dont know where this other fuse is. Im sure its the pump. What do you guys think? Do you know where the mystery fuse is or how to test the relay as well. Thx:)
SPONSORED LINKS
Thursday, August 7th, 2008 AT 3:36 PM
