1989 Other Chrysler Models 89 suburban not getting gas
1989 CHRYSLER
160,000 MILES • V8 • 4WD • AUTOMATIC
BACKFLOW
I have changed the pump and relay. I can put gas in the carb and it runs. What else can it be?
Sep 5, 2009 at 2:45 PM
JDL
  • 16,098 POSTS
I'm not sure of your make and model, a suburban is a chevy?
Sep 5, 2009 at 2:55 PM
BACKFLOW
I just clicked on the wrong one. It is a chevy.
Sep 7, 2009 at 3:40 AM
JDL
  • 16,098 POSTS
If your fuel system is TBI, you should be able to see injector spray pattern. Can you check fuel pressure? When you first turn the key on, no crank, can you hear the pump run for a few seconds? If not there should be a prime connector, close to the relay, red wire with electrical connector, nothing plugged in. If run a jumper wire from battery+ to connector, the pump should run. You don't need to use the key. Use an inline fuse use on the jumper, just in case.
Sep 7, 2009 at 5:40 AM
