1997 Other Chrysler Models major short
1997 CHRYSLER
286,000 MILES • 6 CYL • 2WD • AUTOMATIC
DADJUSTER01
I know it's a chrysler Intrepid.Anyways I was told I have a major short problem causing my car to stall when stoping for a turn or slowing down.Where do I start looking for the problem?[img:ed1fca9127]http://www.2carpros.com/forum/automotive_pictures/247436_163619_1.jpg[/img:ed1fca9127]
Sep 26, 2008 at 9:03 AM
  • 110,244 POSTS
Wow! That's a good one. I would check for codes in the computer. There may be something there. Also, check the simple things. Look for corrosion on the batter terminals, grounds, make sure the battery terminals are clean and tight. Remove the grounds from both the engine block and body, clean and replace.
See if that helps. Hopefully it will be something simple.
Let me know what happens.
Oct 10, 2008 at 8:41 AM
