1996 Other Chrysler Models Passanger window
1996 CHRYSLER
200,000 MILES • 4 CYL • 2WD • AUTOMATIC
CHRIS_WANDER
Good Day
I have a Plymouth Breeze 96 and my passanger window is not going all the way up. How can I fix this? How to open the interior upholstery?
Mar 9, 2009 at 10:22 AM
  • 110,244 POSTS
Hi:
You need to remove the door panel to determine what the problem is. I believe there are a few screws along the bottom and the typical plastic plugs on the back side of the panel. If you have Power Windows, you will need to disconnect the switch from the wiring harness.
Let me know what you find.
Mar 20, 2009 at 6:42 AM
