1992 Other Chrysler Models spark
1992 CHRYSLER
FREAKBOY94
Electrical problem
1992 Other Chrysler Models 4 cyl Front Wheel Drive Automatic
my 1992 plymouth acclaim has no spark i have replace tha coil, s[ark plugs and pickup coil what esle should i check and what would that look like?
Nov 12, 2009 at 2:28 AM
JDL
  • 16,098 POSTS
welcome to the forum, use a testlite on the coil primary terminals +and -, engine cranking. Is there voltage, does the lite pulse? Did you check for codes? You get some codes by cycling the ignition switch, you turn key till dash lites come on, no further. on-off, on-off, on, then the check engine lite starts flashing, you count the flashes to get the codes.
Nov 12, 2009 at 3:03 AM
