replaced parts and cleared all codes except 23 wich is the charge temp sensor oredered it came in but will not fit of corse
PROBLEM is if I turn left It falls on its face and or dies
acts as if its not getting fuel but it should
since then I have replaced all rubber fuel lines, pump, filter and checked presure regulator etc all is good until I turn left still
checked for wires to make sure I wasnt shorting something with steering components etc nothing I can see
at this piont im about to replace the fuel pump agian while it is still under warrenty
thought I would ask here who knows might think of somthing I have not
other things replaced on this car might not matter to issue logic module/distributor pickup/fan/radiator/coil/tp sensor
SPONSORED LINKS
Monday, May 28th, 2007 AT 6:02 AM
