1996 Chrysler New Yorker Starter
81,000 MILES • 6 CYL • FWD • AUTOMATIC
S.A. WATKINS
My car has intermittent starting problems. We are on our third starter in three months. The first starter was the original one, the second one burn the electrical connection between the starter and ignition, which was replaced and a different starter was installed. Now it's intermittent. I turn the ignition and the dash lights come on but nothing cranks. If I do this a few times, ultimately it will start.
It seems like there is a dead spot somewhere.
additionaly, the engine is running really rough but when we put it on the diagnostic machine it shows normal.
Any ideas?
Thanks
Nov 13, 2008 at 3:06 AM
  • 110,246 POSTS
Hi:
It sounds like the solenoid is bad on the starter. I would have it checked at a parts store (bench test). Also, check for vacuum leaks for the rough idle first.
Let me know what you find.
Mar 18, 2009 at 2:24 AM
