1996 Chrysler New Yorker no power
1996 CHRYSLER NEW YORKER
GINAT
Electrical problem
1996 Chrysler New Yorker 6 cyl Front Wheel Drive Automatic 11000. miles
my windshield wipers, speedometer, fuel gage, mileage,power door locks, does not work
Nov 10, 2008 at 1:21 PM
  • 110,194 POSTS
Check for bad ground straps. Also, make sure the connections are good behind the dash. If this all happened at once, you may want to try disconnecting the battery for about 10 minutes to see if it will reset the BCM. If it doesn't, you may want to have that checked.
Mar 18, 2009 at 9:36 AM
