Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Chrysler
New Yorker
Ignition
Timing
1995 Chrysler New Yorker Timing
1995 CHRYSLER NEW YORKER
84,000 MILES • 6 CYL • FWD • AUTOMATIC
KEVIN37
MEMBER
1 POST
How do you adjust the timing for this vehicle. Replaced the Water Pump and must have knocked the timing off as it will not start.
Sep 14, 2008 at 2:50 PM
Experienced Mechanic
You probably didn't set the no.1 piston on its compression/TDC and align the timing sprockets when you remove the timing belt.
Check for spark and fuel-you got both you have to open it up again and redo it-
Sep 14, 2008 at 9:47 PM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
