1995 Chrysler New Yorker Timing
84,000 MILES • 6 CYL • FWD • AUTOMATIC
KEVIN37
How do you adjust the timing for this vehicle. Replaced the Water Pump and must have knocked the timing off as it will not start.
Sep 14, 2008 at 2:50 PM
  • 75,988 POSTS
You probably didn't set the no.1 piston on its compression/TDC and align the timing sprockets when you remove the timing belt.
Check for spark and fuel-you got both you have to open it up again and redo it-
Sep 14, 2008 at 9:47 PM
