1995 Chrysler New Yorker Heater on high
JFISHERBEICK
Heater problem
1995 Chrysler New Yorker Front Wheel Drive Automatic 93,000 miles
My heater is stuck on high and it is 100 degrees outside. The LED does not light up either. I pulled fuse number 6, but it is still on. How can I just shut is off completely for now until I can get to a repair man?
Thanks, Jeanne Fisher
Jun 29, 2010 at 9:58 AM
  • 75,988 POSTS
Remove the AC/Heater fuse and the blower motor relay
Jun 29, 2010 at 10:18 AM
JFISHERBEICK
What number of fuse is the AC/Heater fuse? Where is the blower motor relay located?
Thanks, Jeanne
Jun 30, 2010 at 12:58 AM
  • 75,988 POSTS
Let me ask you this, is it when you off the blower switch or remove the ignition key and it still coming On?
Jun 30, 2010 at 8:39 AM
JFISHERBEICK
By blower switch, do you mean the round thing I turn to increase the fan? Nothing on the console that controls the AC or heater works at all. No lights, no nothing.
You told me to remove the blower motor relay, but I do not know where that is. I also have already removed fuse #6 because I thougnt that was the heater fuse. Did I remove the right fuse?
Thanks, Jeanne
Jul 1, 2010 at 2:43 AM
  • 75,988 POSTS
Try fuse no. 21 25amp
Jul 1, 2010 at 8:58 AM
