1995 Chrysler New Yorker Heater
115,000 MILES • 6 CYL • FWD • AUTOMATIC
SALTYDAWG
The heater isn't blowing hot air. I changed the thermostat with no change. Plenty of coolant. It just blows lukewarm air until the thermostat opens and then the air gets cooler. I suspect there is a vacuum problem. Isn't the control system controlled by vacuum? If so where is it and how can I check it. Thank you.
Feb 8, 2009 at 4:22 AM
  • 110,246 POSTS
Hi:
With the engine hot, running, and the heater on, do both heater core hoses get hot?
Mar 17, 2009 at 2:43 PM
