1995 Chrysler New Yorker engine sputtering
1995 CHRYSLER NEW YORKER
130,000 MILES • 6 CYL • 2WD • AUTOMATIC
THOMAS GONZLALES
I have a 1995 chrysler new yorker with about 130000 miles, every once in a while it seems to jerk and the gages flicker up and down and then it stops. i dont know when it will happen so i cant duplicate the problem. do you have any ideas as to what to check?
also i need help in allining my trunk hood. one end of the latchjes has disco9nnect5ed from the body and i need to get the trunk closed so i take to be repaired. can you give me some sugestions?
Oct 29, 2009 at 3:41 AM
MOPARMAN 01
  • 17 POSTS
Do a code search mine was doing the same it miight be your cam senser but do the code search first that will tell you if it is the cam senser .
Nov 25, 2009 at 6:19 AM
