1995 Chrysler New Yorker Camshaft
1995 CHRYSLER NEW YORKER
190,000 MILES • 6 CYL • FWD • AUTOMATIC
JACK109
Is there a way to test the Camshaft Position Sensor?
Apr 30, 2009 at 7:01 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Pin 1 is +5V, pin 2 is Ground and pin 3 is the signal. Use analog voltimeter in pin 2 and 3. Crank the engine: the pointer of the voltimeter shoud oscilate in range 0V to 5V.
Also you can use diagnostic scan tool capable of testing sensors. This is the easiest way.
Thanks for using 2CarPros.com!
Apr 30, 2009 at 8:01 AM
