1995 Chrysler New Yorker Air Conditioning Not Working &
85,000 MILES • 6 CYL • FWD • AUTOMATIC
HIPPICHIC357
I was driving down the road, air stopped blowing cold, then car overheated. Found blown rad/fan relay and replaced it, but now ac compressor will not come on.
Jul 9, 2008 at 9:49 AM
MERLIN2021
  • 17,250 POSTS
Check to see if you have power at the connector. Fan belt still there?
Jul 9, 2008 at 1:17 PM
HIPPICHIC357
Yes, belt still there.
When I made it home after the car overheated, both electric fans were not working. I checked the rad/fan fuse under the hood and it was blown, so I replaced the fuse. As soon as I turned on the ac the compressor engaged and the passenger side fan came on, but I started smelling something burning and shut the car off. That fuse I had just changed was extremely hot and almost blew again. Today a friend came over and we put the fuse back in and tried to get the ac to kick on, or the fuse to blow, or the burning smell to return, but the only thing it does is idle up/down a bit when I switch the ac on and off inside the car. Now the compressor will not come back on and the passenger side fan does not run. I'm guessing that fan only runs when the ac is running?
Sorry to make this so long, but I want to give you just a little more history --- About 20,000 miles ago the electric fans were replaced with new ones. The ac has had a leak in the top gasket for about that long. I've had to put a can in about once a week. Then, about a week ago I paid an ac shop to replace the gasket and they checked everything, all good. It's been working fine until yesterday when it just started blowing hot air going down the road, then overheated because the fans had quit.
I can take it back to the ac shop, but I would really like to see if I can find the problem before spending any more money...what do you think would make the fuse blow in the first place? Like I said I got the ac to engage when I changed the fuse yesterday, but then something burnt and now it won't come back on and the fuse doesn't blow either. I'll check to see if power going to ac tomorrow and get back to you, but any other info you can help with will be greatly appreciated.
Thanks, Brenda
Jul 9, 2008 at 2:57 PM
MERLIN2021
  • 17,250 POSTS
I need the results of the power test to begin..
Jul 9, 2008 at 3:30 PM
HIPPICHIC357
Ok, I'll let you know tomorrow. Thanks.
Jul 9, 2008 at 3:40 PM
HIPPICHIC357
Hi, I checked the ac, and have power going to the wires. The compressor still would not engage, so I put a gauge on the ac and it is in the red, not showing any fluid in the pump. I could put a can in, but I just had a new gasket put on the ac about 2 weeks ago and everything was fine. I don't know if this matters, but when I removed the ac gauge there was alot of pressure, a big pop. So, I'm not totally sure it's out of fluid, what do you think? I'd really like to try to find out what made the fuse blow in the first place, and what the burning smell may have been when I replaced the fuse and turned the ac back on. That was the last time the compressor kicked in, but when I shut the car off the new fuse was almost blown and extremely hot. Please read my previous comments about the work I've had done to the ac, and about the blown ac fuse. Any help you can give before I take it back to the ac shop, will be greatly appreciated. I just don't want to get down there and spend a lot more money, if it's something I can fix. I'll make it worth it to you if you can help me.
Thanks, Brenda
Jul 12, 2008 at 12:21 AM
MERLIN2021
  • 17,250 POSTS
It might be the clutch coil, can you spin the pulley easily? Or is it binding up? Car off see if pulley turns, remove fan belt to check it.
Jul 12, 2008 at 1:36 AM
