Windows will not go down, the heater switch stopped working?
202,000 MILES • 6 CYL • FWD • AUTOMATIC
JONATHAN BYRD
The windows won't go down and the heater switch also stopped working fine. also abs light came on and airbag and fuse are good. the clear one that i checked.
Nov 12, 2009 at 10:42 AM
  • 110,246 POSTS
Did you check all fuses or only one? Also, the ABS light is most likely a bad sensor at the one of the wheels. You can have the computer scanned at a nationally recognized parts store to check for the source of that problem. Most do it for free.
As far as the other items, check under the hood in the power distribution center. Make sure all fuses and relay are good and not loose. If all looks good, then you will need to start checking for power at the fan motor, window motor...
Dec 19, 2009 at 4:15 PM
