1994 Chrysler New Yorker eletric fan
99,879 MILES • 6 CYL • 2WD • AUTOMATIC
PBOYLAN76
I have a 1995 new yorker and the fan doesn't turn on. I checked relay and fuses everything is ok. No heat in car and overheats.
Mar 26, 2008 at 6:49 AM
JDL
  • 16,098 POSTS
Are you talking about the radiator fan/s? Did you check for voltage at the fuse/s? Are there any troublecodes? The PCM grounds the coil side of the relays to energize them. Did you try jumping the relay to see if the fan would turn on? The computer may use the signal from the cts, to know when to turn the fan on.
If your talking about the blower-motor for the heater, we can try something else.
Apr 2, 2008 at 1:18 AM
