1994 Chrysler New Yorker gauges on dash do not work
1994 CHRYSLER NEW YORKER
275,000 MILES • 6 CYL • FWD • AUTOMATIC
MROBERTS1387
on my 1994 chrysler new yorker, my gauges on the dash do not work. The speedomete, temp gauge, odometer, and fuel level gauge stopped working. also the transmission selector light doesnt come on...but the car works!? Is it a relay or fuse or wiring, and where or how do i fix it?
Feb 26, 2009 at 9:17 AM
  • 110,244 POSTS
Hi:
First check for bad body ground straps. Also, check the plugin in on the rear of the dashboard. If everything looks good, you will need to have the Body Control Module (BCM) tested. Before doing that, however, try disconnecting the battery for about 10 minutes then reconnecting to see if that resets the BCM.
Let me know what you find.
Mar 18, 2009 at 2:12 AM
CHUQUE30815
Is that part a discontinued part or can i purchase it at my local auto zone.
Mar 10, 2012 at 1:27 PM
