1994 Chrysler New Yorker Cooling System
1994 CHRYSLER NEW YORKER
112,000 MILES • 6 CYL • FWD • AUTOMATIC
STACYE
I am having the same problem with my Chrysler. It is overheating and we have flushed it and changed the thermostat. It seems that we have air in the system that we can't get out. Any suggestions?
Jun 3, 2009 at 1:16 PM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:758ebe4d4b="Stacye"]Engine Cooling problem
1994 Chrysler New Yorker 6 cyl Front Wheel Drive Automatic 112000 miles
I am having the same problem with my Chrysler. It is overheating and we have flushed it and changed the thermostat. It seems that we have air in the system that we can't get out. Any suggestions?[/quote:758ebe4d4b]
One way to try to get it out is to run the vehicle with cap loose. You can also try jacking the vehicle up on the side that has the highest access to open the cooling system Don't Open the System. Raising the vehicle there will help move the air bubble to the highest point and hopefully send it on its way throught the radiator.
Jun 3, 2009 at 1:40 PM
MOPARMAN 01
  • 17 POSTS
There is a a nut for bleeding the system on top of the thermostat houseing that will get the air out.
Nov 25, 2009 at 7:18 AM
