1993 Chrysler New Yorker Transmission Dilemma
57,000 MILES • 6 CYL • FWD • AUTOMATIC
JHALL195
The problem I'm having is that when the car (transmission) warms up good, the transmission begins to go haywire. Coming to a stop it will downshift really hard, and when resuming normal driving it will not shift into any higher gears at all no matter your speed. Now if I pull over and put the car in park and turn off the ignition for a minute then restart the car and shift into drive it will drive normally until I stop again. Then the hard downshift, and not changing gears etc... Here's the wierd part, occasionally the speedometer will start jumping erratically and eventually sit at 0, no matter how fast you're going.
My son has a 2001 Dodge Intrepid and is having the exact same problem, and has replaced the following parts, Input speed sensor on the trans, PCM, generator, and had the transmission fluid and filter changed. None of these have fixed the problems. Hope you can help.
Jul 22, 2008 at 1:45 PM
JHALL195
Just wanted to let your readers know that I got my problem fixed! No thanks to any of the web page moderators or owners I might add who appear to only want money to answer questions or provide assistance to those of us who have problems with our vehicles...
Thanks for nothing fellas!
To those of you who are having similar problems with vehicles of this kind, please feel FREE to contact me for the fix. I will be happy to let you know what the solution was.... FOR FREE!
James_B_Hall@hotmail.com
Sep 28, 2008 at 3:32 AM
