1993 Chrysler New Yorker
TESS1954
  • 1993 CHRYSLER NEW YORKER
Engine Mechanical problem
1993 Chrysler New Yorker 4 cyl Two Wheel Drive Automatic over 1 miles
where is the fuel pump relay switch I ran out of gas and now it will start
Sunday, April 19th, 2009 AT 12:15 AM
CARADIODOC
  • 33,916 POSTS
It will start? Do you mean it won't start? What are you trying to do? The fuel pump will only run for two seconds when you turn on the ignition switch, and again when the engine is rotating, (cranking or running).
If you're thinking it won't start until the fuel gets up to the engine, just turn the ignition switch on for a few seconds, then off for at least five seconds, then on again. It won't take long to get the fuel to the engine.
Sunday, April 19th, 2009 AT 1:49 AM
