Windshield wipers not working
1992 CHRYSLER NEW YORKER
GHPCAR
six cylinder front wheel drive automatic 120,000 miles
Windshield wipers stopped working; have replaced motor and fuse; checked switch at steering column and wiper relay and both are good. When I turn the switch on I can hear the relay go on and off depending on the position of the switch setting. I checked for electrical current at plug to motor end and there is some current; what else could be the problem?
Mar 1, 2010 at 6:29 AM
CARADIODOC
  • 34,321 POSTS
Put the wipers on steady slow or fast, then instead of measuring the voltage at the connector, measure the voltage on the wiper motor case. The voltmeter or test light should be grounded to the engine or battery negative post.
When you find voltage on the case, push on the mounting plate and the motor will start to run. The plate is mounted on three rubber isolators to dampen vibration. To get a ground, there is a brass strip riveted to the plate by the lower left bolt. A ring is burned around that strip under the bolt head. Do not bother trying to clean it up. That rarely lasts. Instead, bolt a new ground wire to the mounting plate and bolt the other end to the body sheet metal.
One other note. There must be twelve volts on two terminals at the motor. One from the wiper switch, and one whenever the ignition switch is turned on for the "park" circuit to keep the motor running after the wiper switch is turned off. If one of those voltages is missing, suspect a blown fuse due to your old motor was shorted. It was quite common for one of the contacts on the rotary switch in the motor gear train to overheat. It would melt into the plastic gear when the motor was turned off. The next time the motor started to run, that contact would get stretched and bent up until it touched the metal cover. That popped the fuse. Chances are your old motor is okay if you have the ground problem. It is not likely to develop both problems at the same time.
caradiodoc
Mar 3, 2010 at 5:10 AM
CHEY11MOM
Where is the circuit breaker located? The windshield wipers do not work.
Dec 30, 2016 at 6:07 AM (Merged)
  • 110,194 POSTS
Check fuses under the dash as well as the ones under the hood in the power distribution box.
CHEY11MOM
Thank you so much.
  • 110,194 POSTS
Glad to help. Let me know what you find or if you have other questions.
JACKIE85
Just this morning I took my husband to work and on the way there the windshield wipers worked fine, but on the way home the one on the drives side will not come up. if I make it go up half way it will go all the way but once it goes down it will not come back up. It is a great car but the windshield wiper just will not work now.
BOOTDOG
  • 665 POSTS
either the splines on the wiper arm are worn, or the splines that the arm fastens to are worn.
