1992 Chrysler New Yorker NO POWER TO ANYTHING
MARTY39
88,000 miles. New battery - just had battery checked today to make sure it was not the problem. There is no power to anything....lights, horn, power locks, trunk won't even finish closing. Battery connectors were cleaned. Used key to lock/unlock to disarm security system. What connection(s) can I check to see if there is a simple fix to this problem? Thank you so much for your help. P.S. Guess it probably goes without saying that the engine doesn't crank...not even a peep.
Aug 27, 2007 at 10:33 AM
  • 75,988 POSTS
[quote:d1ff8cc304="Marty39"]88,000 miles. New battery - just had battery checked today to make sure it was not the problem. There is no power to anything....lights, horn, power locks, trunk won't even finish closing. Battery connectors were cleaned. Used key to lock/unlock to disarm security system. What connection(s) can I check to see if there is a simple fix to this problem? Thank you so much for your help. P.S. Guess it probably goes without saying that the engine doesn't crank...not even a peep.[/quote:d1ff8cc304]
Could be battery connections and blown fusible link/s just like a house power you can switch On the living room light all day and nothing is gonna happen if the main breaker trips.
Aug 28, 2007 at 11:07 AM
