1992 Chrysler New Yorker fluid
1992 CHRYSLER NEW YORKER
85,000 MILES • 4 CYL • 2WD • AUTOMATIC
BILL NOLAN
I put transmission fluid in master cylinder when I went dry and had no choice. Will this damage any part of the brake system? and how to correct it?
Jul 29, 2008 at 11:26 PM
  • 31,937 POSTS
Hi there,
The transmission fluid will not be compatible with the rubber components in the braking system, ideally the entire system should be o/hauled & flushed off oil. what will happen over time, the rubbers will soften & swell causing brake failure, this should be rectified ASAP.
Mark (mhpautos)
Jul 29, 2008 at 11:49 PM
