1992 Chrysler New Yorker Battery keeps on dying!
179,000 MILES • 6 CYL • 2WD • AUTOMATIC
DREW1958
The battery is dead after sitting overnight.Replaced the battery and had the charging system checked it was OK. Hook up a meter to see how much it was losing .208mv. I pulled all the fuses under the dash and pulled the relays one by one but it didnt shop the drain. I also disconnented the alternator and starter wires didnt help! What to do????
Aug 16, 2009 at 2:46 AM
  • 110,248 POSTS
When the alterntor was checked, did they check the diodes?
Aug 18, 2009 at 4:41 PM
DREW1958
Yes, they did a complete check of the charging system.
Aug 23, 2009 at 1:56 AM
  • 110,248 POSTS
This is a good one. I even question if a 2.08mv would kill the battery overnight. Use the following procedure to see if there is any difference.
https://www.2carpros.com/first_things/why_is_my_car_battery_dead_over_night.htm
Aug 23, 2009 at 11:10 AM
