Hi thanks for all the help in the past. Need to replace the water pump and it looks like the front crank seal is leaking. Wondering if they can be replaced without lowering or raising the engine. Also do you need a puller to get the front pulley off of the crank. Also any other info that I need to know to make the job go easier. Thanks again, Dennis
Jul 19, 2009 at 9:39 AM
