1990 new yorker
2MUCHDRAMA
i am trying to find out how to unhook the electric trunk. it will not close all the way by itself and it keeps draining the battery.
Nov 15, 2007 at 3:02 AM
MCISME
  • 11 POSTS
Check the fuse panel, if there is a fuse that only is for the trunk then i would pull it. If not then i would check the wire comming from the trunk latch and see if there is a plug. Most cars have wires that plug together and you can simply just unplug them for the trunk to not work with the button.
Jun 7, 2009 at 12:18 AM
