1990 Chrysler New Yorker starter
125,000 MILES • 6 CYL • FWD • AUTOMATIC
JOSHTURNER08
i need to know exactly where the starter is and how i remove it
Aug 10, 2010 at 7:19 AM
  • 75,988 POSTS
1.Disconnect battery ground cable.
2.Remove three starter motor attaching bolts from transaxle bellhousing.
3.Remove two wire connector terminal nuts from starter, then disconnect wire connector and remove starter.
4.Reverse procedure to install.
https://www.2carpros.com/kpages/auto_repair_manuals_alldata.htm
Aug 10, 2010 at 8:13 AM
