1990 Chrysler New Yorker No brakes
130,000 MILES • 6 CYL • FWD • AUTOMATIC
MCISME
  • 11 POSTS
Ok about 2 weeks ago i noticed my brake pedal would travel further than usual before it started to stop. Then i noticed every once in a while i would have a normal pedal but it didnt last.Sometimes the pressure in the pedal would be there and i didnt have to push down far for the brakes to engage and then sometimes the pedal would go down about 1/2 way b efore i started to stop. Today i started the car up and steped on the brake and it went straight to the floor. if i pump the brakes i will get very lil pressure. There are no leaks and the Master cylinder is full.
What would be the problem?
Sep 2, 2009 at 11:38 PM
  • 110,248 POSTS
It sounds like you need to replace the master cylender. Chances are one of the o-rings inside is bad and the fluid is bypassing it.
Try that and let me know if it helps.
Dec 19, 2009 at 4:54 PM
