1990 Chrysler New Yorker Driver door water shield
1990 CHRYSLER NEW YORKER
98,000 MILES • 6 CYL • FWD • AUTOMATIC
DAVEMASTER
  • 5 POSTS
Recently my driver door power window gave out. Turned out to be a broken flex track from use/age etc. Replaced it and now the window works great. However to access and remove the regulator I had to remove the water shield which required a herculean effort. As a result, it is now unuable for it's intended purpose as it is all stretched out and bumpy. How can I obtain a replacement? What would be the estimated cost ?
Apr 15, 2009 at 12:21 PM
JAMES W.
  • 2,394 POSTS
The part you are looking for would be a "dealer only" item. Estimated cost, about $25.00.
Apr 15, 2009 at 12:28 PM
CARADIODOC
  • 34,381 POSTS
Just put a bead of silicone RTV sealer around the outside edges and work it into the plastic shield. No one ever replaces these. If the sheet is torn in the middle, just overlap the edges and put a bead of RTV sealer between them. If you still want to replace it, just grab a roll of plastic sheeting from your local hardware store and cut a piece to match.
By the way, when you reinstall the large diameter pin at the end of the flex track, if you put it in the other direction, putting the clip back on is easier.
caradiodoc
Apr 18, 2009 at 7:38 PM
