1990 Chrysler New Yorker
JBLAY36
1990 Chrysler New Yorker 6 cyl Two Wheel Drive Automatic
how to i fix an inner tie rod on a 1990 chrysler new yorker
Jun 4, 2008 at 5:42 AM
FERMECH
  • 14 POSTS
You need two special tools that maybe you can rent from your local parts store.
One is a fork to remove the outer tie rod.
Second is a long socket to remove the inner.
Remove tire undo the outer tie rod and remove completely then remove dust boot and place long socket over rod and remove.
You will need a wheel alignment after this job. Good luck!!!
Jun 4, 2008 at 2:33 PM
