1988 Chrysler New Yorker interior lights dont shut off all
KIEROS
Electrical problem
1988 Chrysler New Yorker 6 cyl Front Wheel Drive Automatic 177k miles
all the door relays have been checked and the switch is checked when u switch all interior lights on the lights get brighter as if more power directed to them I have to remove fuse to stop the power drain when unpluging
the lights seem to be on the radio's fuse please advise
Dec 3, 2009 at 3:39 PM
CARADIODOC
  • 34,413 POSTS
Check in the fuse box for a timer delay. It is a silver can, about 3/4" around and 1 1/4" long. Looks like the plug-in starter for an old fashioned florescent light fixture. These were used to keep the ignition switch light on for a few seconds after you shut the doors. They might be using one for all your interior lights. If the contacts arc and stick together, the lights won't turn off. Tapping on it might break the contacts loose, or you can just remove it. If you want to replace it, you'll find hundreds of them in the salvage yards. They don't fail very often.
REAL good observation about the lights getting just a little brighter when you turn them on with the headlight switch. That's a trick I use with the brake warning light on the dash. Three different switches can turn that light on. Observations like that make our job a lot easier.
You're correct about it being related to the radio fuse. The memory circuit for the station presets and the clock must be tied into a circuit that is hot all the time. "Interior lights" is the most commonly used circuit.
caradiodoc
Dec 4, 2009 at 7:11 AM
