1987 Chrysler New Yorker Car stalls when I brake in Drive
90,000 MILES • 4 CYL • FWD • AUTOMATIC
DMUNSELL0001
Whenever I am in drive and stop at a red light 9 times out of 10 the car stalls out. However if I kick it into Neutral while I'm slowing down it does fine. I have no idea where to even start looking for this problem and any help would be appreciated.
May 9, 2009 at 5:44 AM
  • 110,248 POSTS
Has the check engine light come on? Also, when was the last tune up? Also, have you had the fuel pressure tested?
May 11, 2009 at 12:16 AM
DMUNSELL0001
I haven't had the fuel pressure tested and the check engine light is not on. I last did a tune up a little less that 10,000 miles ago.I did a fuel system cleaning and the problem got better but the idle still drops pretty bad when im coming to a stop and then gets better once im actually stopped
May 11, 2009 at 10:58 AM
  • 110,248 POSTS
I really feel it has to do with the TPS or IAC, but without a check engine light to confirm, it is a guess at this time.
May 12, 2009 at 12:36 AM
STAVO1987
I have replaced the TPS,IAC and gave it a tune up (plugs, wires etc) no codes
Dec 22, 2017 at 10:22 AM
Good morning
Just to add another possibility, it could be the transmission not downshifting causing the stalling as well. If it is still in a higher gear and does not downshift quick enough it would be like coming to a stop with the stick shift and not pushing in the clutch.
has the trans been serviced???
Dec 22, 2017 at 8:06 PM
STAVO1987
Yes Sir, the transmission was serviced about 4 months ago. Problem was preexisting and continues
Dec 26, 2017 at 9:17 AM
Have you had a transmission shop check the transmission???
Dec 26, 2017 at 9:29 AM
STAVO1987
No Sir, I will try that.
Dec 26, 2017 at 9:48 AM
ok, report back to us with the results
Dec 26, 2017 at 9:50 AM
