1982 Chrysler New Yorker FUEL LINES
100,031 MILES • V8 • 2WD • AUTOMATIC
RANDY LOWE
IM RUNING NEW FUEL LINES I WANT TO KNOW WAT LINES RUN WERE THERE ARE 3 LINES COMJNG OUT OF TANK IS ONE TO THE FUEL PUMP AND ONE A RETURN LINE WHAT IS THE OTHER??AND IS IT SAFE TO RUN RUBBER OR SHOULD I USE HARD LINE.THANKS FOR HELP!!!
May 13, 2010 at 4:17 AM
CARADIODOC
  • 34,413 POSTS
The third line is a vapor line for expanding vapors in the tank to go to the charcoal canister. Rubber hose will work fine.
caradiodoc
May 30, 2010 at 5:55 PM
