I recently purchased this vehicle and I have a problem with the air conditioner. I checked all the system components and everything appears to be working. I bought a recharge kit and filled the the system with as much as it would take. The problem I am having is that the system is working crazely. I can start the car and the air conditioner will work. I will shut off the car and next time I start it the system will blow hot air. I turn off the car and re-start it and the system will work. Other times it will not work no matter how many times I re-start the car. It also seems to work better on the regular air conditioner setting rather than on max settings. Any help would be appreciated. I have tried checking to see if the unit switches from air to heat and back and it does.
Thanks,
Dan
Thanks,
Dan
Aug 3, 2008 at 1:43 AM
