2002 Chrysler Neon radiator cracked by hose fittings
2002 CHRYSLER NEON
82,000 MILES • 4 CYL • 2WD • AUTOMATIC
PATSYCBK
mechanic says I need new radiator and transmission and high pressure lines?..I didn't run over anything, didn't hit a curb or even a pot hole..what could have caused this to suddenly happen?..I did put it in the ditch this past winter, 4 months ago, and had to towed out..could this have caused stress on the fitting and radiator?
Does anyone have any answers or is this a common Neon problem?
May 4, 2009 at 1:04 PM
BMRFIXIT
  • 19,053 POSTS
Some normal wear and tear
the winter will cause a lot of it
May 4, 2009 at 1:46 PM
