The turn indicators on my baby have been slowly failing. They were for a time flashing briefly and then stopping, but most of the time now they will not turn on at all, though I can sometimes manually flash.
The emergency flashers had for ages frozen when left on for 10 minutes or so, but now they also will not go on at all.
I first thought it was a fuse, but the shop said that a fuse would be indicated by not working at all, suddenly.
So I tried to replace the flasher relay, in my car a little cube with several pegs to plug in. This did not solve the problem.
I note that in the thread on flashers there is mention of the indicator switch needing to be repaired. Is this something that is easily done, or do you need to really know what you are doing. The response went on to say that the steering wheel needed to be pulled to replace it, using a special tool.
Please advise?
Please advise?
Mar 19, 2010 at 11:00 AM
