2000 Chrysler Neon Timing Belt
15,000 MILES • 4 CYL • 2WD • AUTOMATIC
EPILYNN
I went to start my 2000 neon and it made a popping noise and never started. after a couplr seconds of cranking i realized the timing belt was broke. Im wondering if i could have bent valves. I habe no compression in any of the cylinders
Apr 22, 2009 at 9:37 AM
  • 110,248 POSTS
You may have bent a valve, but have you replaced the timing belt yet?
Apr 22, 2009 at 10:12 AM
EPILYNN
[quote:47f17e38a0="Jacobandnickolas"]You may have bent a valve, but have you replaced the timing belt yet?[/quote:47f17e38a0] Yes, and I don't have compression in any cylinder
Apr 22, 2009 at 11:06 AM
EPILYNN
Yes and still no compression in any cylinder Why would this be?
Apr 22, 2009 at 11:07 AM
  • 110,248 POSTS
If you have 0 compression in all cylenders, the crankshaft and cam shaft are turning and it is in time, the only thing left is to remove the cylender head to get a visual. I can understand a bent valve but not all of them.
Apr 23, 2009 at 5:10 AM
AVMEC
it almost sounds like it is not timed right If you bent a valve you would have 0 compression in one maybe two but 0 in all you do not have it timed right most likely 30 degress off
Oct 4, 2009 at 7:40 AM
  • 110,248 POSTS
I agree, but I feel he would have compression to some extent in one or more cylenders.
Oct 4, 2009 at 8:33 AM
