2000 Chrysler Neon Timing Belt
EPILYNN
  • 2000 CHRYSLER NEON
  • 4 CYL
  • 15,000 MILES
I went to start my 2000 neon and it made a popping noise and never started. After a couplr seconds of cranking I realized the timing belt was broke. Im wondering if I could have bent valves. I habe no compression in any of the cylinders
Wednesday, April 22nd, 2009 AT 4:37 PM
  • 109,885 POSTS
You may have bent a valve, but have you replaced the timing belt yet?
Wednesday, April 22nd, 2009 AT 5:12 PM
EPILYNN
Yes, and I don't have compression in any cylinder
Wednesday, April 22nd, 2009 AT 6:06 PM
EPILYNN
Yes and still no compression in any cylinder Why would this be?
Wednesday, April 22nd, 2009 AT 6:07 PM
  • 109,885 POSTS
If you have 0 compression in all cylenders, the crankshaft and cam shaft are turning and it is in time, the only thing left is to remove the cylender head to get a visual. I can understand a bent valve but not all of them.
Thursday, April 23rd, 2009 AT 12:10 PM
AVMEC
It almost sounds like it is not timed right If you bent a valve you would have 0 compression in one maybe two but 0 in all you do not have it timed right most likely 30 degress off
Sunday, October 4th, 2009 AT 2:40 PM
  • 109,885 POSTS
I agree, but I feel he would have compression to some extent in one or more cylenders.
Sunday, October 4th, 2009 AT 3:33 PM
